EICO 360 Sig generator and sweeper
Can anyone tell me how to calibrate this? I cannot seem to find calibration instructions anywhere..
Thanks
Skip...
Usually when calibrating an oscillator one needs a calibrated counter of the precision higher than that of the DUC.
Looks like there is a manual on ebay.... https://www.ebay.com/i/263381568918?chn=...1902804856
I have the manual.. No instructions in it on Calibration..
It does seen to work OK Just wanted to get the frequencies to Track with dial IF possible..
Skip...
I think if you want it to be really accurate you need the 10.7mhz xtal.
There are currently 10227 online users. [Complete List]
» 1 Member(s) | 10226 Guest(s)
