H-940 model ???
Hello Philco Friends !  How are you
This huge console is proposed on a french site , fitted with a radio set " Philco " , which seems to be a h-940 one
Do you know this model ?
Do you think the console is a Philco one , or a french made one , ?
Here after some photos the vendor sent to me
Thanks for your answer Icon_biggrin
This is a midcentury modern. Maybe someone here is into that.
Pas ma tasse de the. Icon_smile
As the resident mid century modern guy (who lives in the 1960 mid century ranch house) Icon_smile ...
That is not Mid Century Modern.
It looks more like the "Mediterranean" console style that was popular from the late 1960s into the 1970s, before stereo components began to take the place of those yuuuge floor model console stereos.
As for the model number, ordinarily the H in H-940 would indicate 1960 model year. But this stereo is much newer than 1960. It's clearly solid state and uses the Philco-Ford logo. I don't believe the Philco-Ford logo came into being until at least the mid-1960s, even though Ford bought Philco out in 1961.
If it was intended for the UK and European market (including France), then the model number may not mean anything (from a USA Philco perspective, that is).
Hello Sirs
Thanks a lot for explanations .
Yes indeed , it's a huge console and I do'nt intend to buy it !!!
I just want to inform the vendor , if possible !
here is the associated turntable .
My father used to own one of those, it's from around 1972 if I remember correctly, the cabinet was called "Spanish". There were some differences though, such as the record changer was black, not silver and chrome, the woofer speakers were 12 inch round, pincushion framed, rocker switches rather then slide switches, and the unit was branded as a "Silvertone" since it was sold by Sears, apparently made in Canada as well.
Thanks a lot Arran , for your witness and your explanations !
regards
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
