Philco 70 Cabinet
Ok,, This has probably been asked a lot of times before.. But here goes.. What does the Cabinet look like for a model 70 Early version NO AVC.. Reason asking is every picture I see is different..
Can someone point out a picture that is original.. Or does the model 70 use many different type of cabinets and finishes..
Thanks
Skip...
http://philcoradio.com/gallery2/1931b/#M...Baby_Grand
is the popular one but there are a number different cabinets , consoles, clock/radio and a chairside.
And there are slight differences in cabinet built and finish in Canada, as compared to the U.S.
Only speaking of the cathedral style 70. The cabinets were the same for the early (non AVC) and late (AVC) chassis. There were two styles of base moulding used. I have seen early chassis in cabinets with either style base. The craftsmen did take some liberty on the finish.
M R Radios   C M Tubes
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
