Unknown Philco
All, Please ID this Philco..I picked this up at Kutztown a couple of years ago from Kirk I think.. Cannot remember the model Number..
It has 11 Tubes..
[Image: https://farm5.staticflickr.com/4599/3855...d11f_b.jpg]
[Image: https://farm5.staticflickr.com/4736/3855...7d89_b.jpg]
[Image: https://farm5.staticflickr.com/4685/3855...cc65_b.jpg]
Thanks
Skip..
Try 111.
I do not think so. The bottom doesn't match what I have..
Skip...
It's a late version 112 using two 47 output tubes. Notice the two Mershons and the smaller multi-section filter cap can.
This is 112.
111 has large cap can.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
