Threads: 30
Threads: 566
It is 1800 ohm FIELD coil. Your voice coil is likely to be from 0.7 to 4 ohm.
Now that you don't have the speaker and probably missing your output xfmr too, just get a proper size speaker and match the transformer.
The sch is similar to Philco 20 but with A output stage so a speaker from 70 could do.
Threads: 268
Or a Philco 90 w/single 47. I think I see one.
Threads: 566
Yep. Thy are practically the same. Or are the same.
PS. Make sure if it is a 90 speaker it is from the one with a single 47 out, not a pushpull one.
Threads: 30
Ok! I'll just steal the one closest to the Phonola right now... ;)
Threads: 30
So, I did some measuring, and comparisons... and a Philco 70/90 speaker won't physically fit into the cabinet, between the decorative bolts. Actually, none of the multitude of speaker I have around here will fit the bolt pattern they used.
So, I did a bit of research, and using a picture of a similar set I found online, and a same-year battery set I have here...it seems that Grimes was using Utah speakers, made by their Canadian division.
Threads: 30
I have located a speaker that will fit. But, the field coil is 2600 ohms, which puts it 800 ohms higher than the original. I know that one can roughly go 300 ohms higher than the original value, without affecting the B+ voltage too much. But those calculations are also based on a +- 110 volt power source. Out here in rural Alberta, where I live, the line voltage is running 128 volts. Does anyone have experience using a speaker with a higher field coil value? Maybe the B+ will still be ok? Any issues in doing that, which might affect the power transformer?
Threads: 566
Brad, you can put a power resistor in parallel to bring the value in line with requirements.
Yes you might want a bit higher value, maybe 2000 ohm as the resultant from the parallelling.
Threads: 54
Brad;
Try looking through some of the U.S Radio and TV schematics, some of the Phonola sets from that era are Kitchener built clones of those sets, I have one that is basically a gothic Gloritone in a slightly different cabinet, and says "Dictator" on the escutcheon rather then "Gloritone".
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
