LOOOONG WIRE
I ran a long wire antenna about 70 feet high. Thought i had after 9pm radios only . Only time get anything .
Then had a idea telephone . I only use two wires in my interface box out side . The other two are for extra lines .
So i hooked a wire to them now i have a loooong wire antenna . Works great does not bother with phone any.
Did it on customer access side. Try it . Icon_biggrin Now i get stations all day. Icon_biggrin
Kent.
Watch that ringing voltage! Icon_idea
No ringing voltage Icon_wink Just extra wires running a long way down the line. Icon_biggrin Can you hear it now Icon_lol
KENT.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
