Philco 70a Technical documents?
Could anyone here help me out? I have a 1931 Philco 70a (less than b22000 model) and am looking for a sheet that identifies the parts under the chassis. I have a schematic but it has many components simply labeled with numbers from 1-50 or so. I'm looking for the matching document that shows where those numbers are on the underside of the chassis. Thank you.
http://www.nostalgiaair.org/Resources/833/M0013833.htm
Welcome to the Phorum!
Icon_wave
There is also a cleaner version of the docs on nostalgiaair on the audiophool site: http://www.audiophool.com/Philco.html
You do need to download the djVu reader. A link to that is found here: http://www.audiophool.com/index.html
Hey @David, those are exactly what I'm looking for but it seems the ones you linked are for models above b22000. Do have any for the under b22000 model? Thanks!
Hope this one is it!
PM me with your email address and I can send you what I have..
Skip..
91H Code 126 Restore
