Threads: 14
City: Wyoming, PA
Hello all, luckily I printed the part number breakdown for the Bakelite blocks from the Philcorepairbench website a few years ago. I don't see that info on their website there anymore?? Anyway, I can't find info on several Philco part numbers from my model 18 I am doing. Specifically, the voltage ratings for:
3615AM, 4989AC, 3615AA, 8035K, 3903Z, 4989N, 3793AB, and 3793R.
Further, do I really need a 600V rating on: 3903P, 6287N (.09, .15uF), and 3615G (.05uF)
Any other resources out there for these Bakelite block part numbers? Thanks so much, Jeff
Wayback Machine to the rescue!
https://web.archive.org/web/201603242327...lokcap.htm
I would use 600 or 630V caps to replace every paper capacitor if it were my radio.
Threads: 14
City: Wyoming, PA
Threads: 19
City: The Motor City,Detroit MI
(01-04-2018, 01:20 PM)Ron Ramirez Wrote: I would use 600 or 630V caps to replace every paper capacitor if it were my radio. As a reminder, that includes the .00011 uf capacitors, which are paper. They are replaced with 110 pf mica capacitors.
Threads: 14
City: Wyoming, PA
Hello, thanks for the replies. The link Ron shared is great but doesn't list all part numbers and codes. The ones I questioned aren't listed; for example, 3615-AA. Is there any way to find out for sure what these part numbers are? Thanks.
Yes - buy the book by Ray Bintliff, if you can find a copy. Ray was selling his remaining copies here on the Phorum (through a Phorum member) a few months back but I believe they are all gone now.
I did notice that the Antique Radio Classified site is still advertising Ray's book on this subject. I do not know if they did a reprint, if it is still available, or what.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Yes, Ray's book is getting hard to find. If you still need it...
[Image: https://www.dropbox.com/s/ez9ognly6tuxer....jpg?raw=1]
Threads: 14
City: Wyoming, PA
Hello, I found what I needed here on this wonderful site. Under: Philco restoration notebook, there is a link to the Philco Tech section, a thread labeled "Philco Bakelite block condenser data, then Ron put a link to a PDF file which is an original publication from Philco dated 1937 which lists all old obsolete Bakelite part numbers (all of mine in question are there  ) and a suitable replacement part number. Thanks a lot!!
http://philcoradio.com/phorum/attachment.php?aid=10650 here is the link to the pdf
(This post was last modified: 01-10-2018, 10:33 AM by jeffb.
Edit Reason: forgot to add link
Threads: 19
Make sure the bakelite block you're working on matches the documentation in that link. For example, I recently found more than one block wired differently from the document for the same block number. Instead of the single capacitor tied to the farthest points as shown in klondike's sketch above, they were wired to adjacent points. Take a peek at the wires coming out of the cavity to the tabs before you proceed, and match them accordingly.
(This post was last modified: 01-10-2018, 10:46 AM by Kestas.)
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 3671 online users. [Complete List] » 2 Member(s) | 3669 Guest(s)
