RP-2 Tone Arm Pivot Questions
Working on a 41-RP2 with bad rubber in the tone arm pivot assembly -- as in no rubber left at all, it's completely disintegrated to powder. I'm trying to figure out the best way to replace the rubber, but I don't know for sure how it's supposed to fit together, or how thick the rubber itself should be. Does anyone have one of these with original rubber intact, who could give me a quick description of how it should go together?
Many thanks!
Hi
I've owned a couple of these in the past, but it has been a while, and I frankly do not recall any rubber in the pivot assembly. Sorry.
You might want to contact these fellows:
http://www.west-techservices.com/
They could probably help you out.
Good luck.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
