Station Identifier Replacement on 39-55
Is it possible to replace the station identifier labels in a model 39-55 without having to de-solder the pilot lamp assembly?
Yes.
The escutcheon is held on by eight small screws. Remove these, then pull the escutcheon loose.
The eight indicator lamps are held in place by small clips, and should pull off the escutcheon easily.
Take notes, drawings, pictures (or a combination of these) to remember which lamp goes in which hole when you are ready to reassemble!
I don't remember exactly how the call letter tabs are held in on this escutcheon, sorry.
The steel fabrication that receives the lights, and also holds the call letters in place, is a single piece that, unfortunately, is soldered to the escutcheon. I'm afraid that if I attempt to un-solder that portion, it will discolor the brass face of the escutcheon.
OK, once again I proven myself to be stupid! The call letters were printed on some sort of paper product that slipped into individual slots on the escutcheon. Now, all I have to figure out is how to duplicate the original product.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 4093 online users. [Complete List]
» 1 Member(s) | 4092 Guest(s)
