Station Identifier Replacement on 39-55
Is it possible to replace the station identifier labels in a model 39-55 without having to de-solder the pilot lamp assembly?
Yes.
The escutcheon is held on by eight small screws. Remove these, then pull the escutcheon loose.
The eight indicator lamps are held in place by small clips, and should pull off the escutcheon easily.
Take notes, drawings, pictures (or a combination of these) to remember which lamp goes in which hole when you are ready to reassemble!
I don't remember exactly how the call letter tabs are held in on this escutcheon, sorry.
The steel fabrication that receives the lights, and also holds the call letters in place, is a single piece that, unfortunately, is soldered to the escutcheon. I'm afraid that if I attempt to un-solder that portion, it will discolor the brass face of the escutcheon.
OK, once again I proven myself to be stupid! The call letters were printed on some sort of paper product that slipped into individual slots on the escutcheon. Now, all I have to figure out is how to duplicate the original product.
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
Mike, check out the 42-PT2. RodB — 06:04 PM
