Philco 46-1226-125
Hi been looking for a photofact copy for a philco 46-1226-125 console radio I have cant seem to find one in my usual sources Any one have an Idea   Thanks Chris
Welcome to the Phorum!
There are a number of schematics downloadable from the Audiophool site including the 46-1226:
http://audiophool.com/Philco.html
They are in DJVU format so you'll probably need to convert to PDF in order to print.
-Nathan
Icon_wave
thats because there are none.
what there is available is updates to the three codes known and the run numbers associated to each.
to find prints , the philco workbench will be the best bang for your buck. 10$ i think.
to find prints as well, use my thread by typing in the upper right,, " 46-1226 code 125 "
look for my thread
Hi Thanks for your replies Now I can get started on this project its been on my bench for a week .....Chris CB
91H Code 126 Restore
