Philco 90/91 Question
Will a 90 fit in a 91 cabinet? Ken
I mean will a Philco 91 fit in a 90 cabinet??? Ken
Ken
Yes, a 91 chassis will fit in a 90 cabinet - IF you remove the shadow meter.
A 90 chassis will also fit a 91 cabinet, but of course the 90 has no shadow meter...
Icon_smile
Thanks, Ron. You're the only one who knew this. Ken
There are currently 8499 online users. [Complete List]
» 1 Member(s) | 8498 Guest(s)
