Philco 41-90 output transformer 32-8100
I decided to start to work on my 41-90 since it a less complicated unit. I have ordered my Cap's
my problem is I would like to get some info on my output transformer which is a 32-8100. Is there
a link I can go to to get the specs on this, or a good book, to be able look up this kind of info.
Thanks
Bruce
Hi Bruce
The 1946 Philco parts catalog states that this transformer has a 25K ohm primary impedance, 3 ohm secondary. It's rated at 4 watts output although I doubt the 41-90 is capable of even putting out 1 watt since it is a small battery-operated receiver.
OK thanks for the info and where can i get a parts catalog?
Thanks for all the help.
Find some great info here http://www.radiomuseum.org/r/philco_41_90.html Icon_biggrin
Kent.
I got luck and found one on ebay 25k to 4 ohms
just waiting on caps to get started. Thanks for
everyone's help. Icon_biggrin
Philco 89 indicator light.
There are currently 4433 online users. [Complete List]
» 4 Member(s) | 4429 Guest(s)
AvatarAvatarAvatarAvatar
