Philco 16B & 116B instruction pamphlet
Threads: 14
City: Bakersfield, CA
Does anyone have the instruction pamphlets Philco included for either or both of these radios - 16B and 116B?
I am looking for the instructions for the code 121 radios... the early 1935 art-deco tombstone and the early 1936 shouldered tombstone.
Thanks for your help. I haven't found either of these yet on this site. Maybe I just missed them.
I have included pix of the radios just to be clear.
Scott
Image(s)
(This post was last modified: 02-05-2018, 06:29 PM by
Scott D .)
Threads: 91
City: Jonesboro
State, Province, Country: AR
Scott,
Did you check the Downloadable files section? I found some info on the 16, not sure if this is what you're looking for. There's also a thread with the 116X manual available. It should be similar to the 116B, since the coverage and controls were the same.
http://philcoradio.com/phorum/showthread.php?tid=6871
http://philcoradio.com/phorum/showthread.php?tid=12809
If this isn't what you're looking for, a hunt through the internet is probably called for, unless a member here has it, and just hasn't scanned and made it available yet....
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 14
Thanks Jeff. I already found the 116X pamphlet and the 16B code 125 sheet. Just nothing specific on on the two I mentioned. A first hunt on the internet turned up nothing. I will keep looking though. If it find them, I will post and share them.
Threads: 562
The lower pic radio doesn't seem to be a 16 or 116.
Mike, it is a 116B alright, just refinished incorrectly (no two-toning).
Threads: 14
Indeed Ron, it is not done correctly... but, beggars can't be choosers. I will correctly redo it when I retire some day - lol! That said, here is the interior tube layout sticker.
Scott
Image(s)
Threads: 562
Yep, now I can see it. I thought it was 620 or such.....it almost looks smaller that way.
Threads: 11
City: Bellmawr, NJ
I think it is a 620 also,,,,,,BUT,,,I'm known to be WRONG a lot,,,CHEERS
Threads: 562
Ken
No, it is not a 620, it is indeed a 116B.
Threads: 11
City: Bellmawr, NJ
OH,,,I believe you--ALL,,,,,I see the base is Different,,,,
Threads: 14
It'd hard to argue with the tube layout label.
While the finish isn't as it should be, the 116 is a strong player on all bands. Now, if there was just something descent on radio to listen to... lol!
BTW - I'm still looking for those operating instruction pamphlets!
(This post was last modified: 02-09-2018, 08:59 PM by
Scott D .)
Quick progress report:
I've replaced...R3Sons — 05:05 PM
All need to go and be replaced.morzh — 04:36 PM
Hi Rod,
The resistor connects to pin 4 and the ungrounded side of block 9. From pin 9 of the RF tube to one side of ...dconant — 09:34 AM
Hello Tim,
Sincerely Richardradiorich — 01:55 AM
