Emerson 267
Looking for schematic/info for an emerson 267 (CG267?) radio
Found a cg-268@http://www.nostalgiaair.org and a cm -267 http://radiomusem.org/r/emerson_cm267.html
Kent.
Yeah looking for component values.
Someone's been into this and god knows where to start..
Thanks Kent
I looked Are you sure this is model not chassi number. Check see if the 268 might be same schematic.
This comes up at NostalgiaAir on a 267 search.
http://www.nostalgiaair.org/PagesByModel...004951.pdf
http://www.radioatticarchives.com/radio.htm?radio=4792 is this your set . If it is this guy maybe able to help http://www.radioattic.com
Or this http://www.radioattic.com/toppo
Yet the Radioattic pic is the correct radio.
I did get the number from the chassis as all the decals are gone.
I printed out the CM267 schematic and it looks more correct than what I had. Will have to investigate.
Thanks guys
Ilooked through all schematics up to 1953 no cg267 .Ithink the cg268 is the one you need.
Philco 91 Tuning Condenser
