Internal loop connection 40-190
Took out the loop in the top of the cabinet during cabinet restore. Put it back in ,got one side to the tuning cap,where does the other side hook up? Schematic says ground but wire will not reach . Loop is stock afaik.
Hi SS and welcome,
The small loop is for the SW band and connects from chassis ground (short wire at the tuning condenser) and lug 3 on the back terminal strip long wire.
Welcome to the Phorum!
Icon_wave
Lug 3 was blank ,sw ant. wire fit ok there.! Kinda funky sw ant. Thanks for the help. Sure I will be back with more questions. Icon_biggrin
The speaker table error?
Philco 70 antenna lead
