Superior TV-10 tube Tester
Just picked this up yesterday..
[Image: https://farm5.staticflickr.com/4698/4028...806f_b.jpg]
Works Ok Havent given it a good checkout yet.. Bottom of case isnt in great condition...
Need any information anyone has on this.. Instruction,Schematic,ETC..
Thanks
Skip
Not much out there but there's a photo of the instructions here:
https://tubedatabase.co/testers/superior-tv-10
There are a number of comments that it's similar to the TV-11 which BAMA does have:
http://bama.edebris.com/manuals/superior/tv11/
Thanks Helps a lot..
Skip
I have  the tv11
work fine   just 1.5 volt test are Effie.  some times blows tube out
sam
Here is the inside of my TV-10 No tube.. No Diode either.. Unless the black thing in 2nd picture is a diode?
[Image: https://farm5.staticflickr.com/4753/3953...f89a_b.jpg]
[Image: https://farm5.staticflickr.com/4697/3953...f100_b.jpg]
Skip...
Does anyone own one of these that can take pictures of inside and knows what parts are what???
Skip
I realize that this is an old thread, but just in case, I thought I'd let you know that I just got mine out of long-term storage. I've just now brought it all the way up to 120 vac over the last 24 hours of break-in. It seems to work (I tested the line adjustment, as shown in the photo), but I haven't tested any tubes yet. I just need to find something that needs testing. I think this item is completely original and in great shape, all things considered. If you need any photos or other data, please just ask. Also, thanks for setting up the original post and what followed.
sure, any photos you can either send or post here will help..
Will send you a PM with my email address
Thanks
Skip
Eico 232 VTVM Schematic
There are currently 9378 online users. [Complete List]
» 2 Member(s) | 9376 Guest(s)
