Philco 91 Code 125
I'm trying to find servicing information for this model and not having much luck at all. Have found lots of info for other model 91 codes but nothing for 125. Chuck at the Philco Repair Bench even struck out. Thanks for any help you can give me!
Bruce
This is probably pretty close, especially if (a) your set has individual tube shields instead of one large tube shield on the left of the chassis (as seen from the rear of the chassis), and (b) your set is dual band (AM and the old "police" band):
http://www.philcoradio.com/images/phorum/schem/1491.jpg
Thanks Ron. My set does have the dual band but it has the one large tube shield and not the individual ones.
The speaker table error?
Philco 70 antenna lead
There are currently 6189 online users. [Complete List]
» 1 Member(s) | 6188 Guest(s)
