Philco 40-95
Is this model suppose to have any decals, i.e., "Philco", ""On/Off". If so, can you tell me the size and placement. Thanks.
Look here:
http://www.philcoradio.com/gallery/1940a.htm#f
The only decal is the PHILCO trademark above the dial.
Don't buy those PHILCO decals from Radio Daze - most of those use a font which is totally incorrect and look awful...in my opinion. I'm referring to part numbers PH1, PH2, PH3, PH7 and PH9. Use the S-M907 sheet from Antique Electronic Supply instead, and use the largest PHILCO trademark on the sheet. Sure, you'll be left with many decals you don't need for your 40-95, but your radio will look right.
When Mike Tobin first designed those decals for Rock-Sea Enterprises, I told him the fonts were wrong, and showed him examples. He corrected them...but about that same time, he sold his business to Radio Daze...and Radio Daze kept his original font design instead of the corrected design. I cringe every time I see a refinished radio using a Radio Daze decal.
Now, the Radio Daze PH8 decals aren't too bad for 1932-1936 Philcos...not quite correct, but not awful. And their PH-HiFi decals are pretty much dead-on to the originals. One could cut the "High Fidelity" off the sheet and just use the "PHILCO" above and have PHILCO decals with correct fonts.
Yes, I'm picky when it comes to things like this. I'm still angry at myself for knocking a spot of new lacquer off a freshly refinished 97B cabinet I just picked up from Barry Jones, cabinet refinisher extraordinare, yesterday.
Thanks for the information. I'm glad I asked because I had some radio daze decals.
Finished product.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
