Philco 37-660 chassis question
I am looking for parts for this chassis and was wondering which other models used the same design as the 37-660.
I am trying to locate a replacement for the band select lever.
Bill
Bill, your best bet is to look here and compare specs. I'd imagine without looking, that many sets use the same switch. Quite a job to change out I might add with one of these "sub-chassis" sets.
http://www.nostalgiaair.org/Resources/303/T0000303.htm
EDIT: From what I can tell, your switch is unique to this set. The following part numbers are used
antenna rg(range) sw(switch)
42-1202
RF rg sw
42-1203
Oscillator rg sw
42-1204
Indexing plate & shaft
42-1186
If I'm reading this correctly, I couldn't find any other set using the same part numbers.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Thanks for your response. It looks like I may have to try and rebuild it. I have been asking around and haven't located a replacement for it.
Bill
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 3931 online users. [Complete List]
» 2 Member(s) | 3929 Guest(s)
