Knobs for Philco 52-1731
Hello: I'm restoring a Philco 52-1731 cabinet and am missing 2 of the 4 tuning knobs. Any suggestions on where to obtain 2 of these could be much appreciated. Images of the knobs are attached. Thanks!
Welcome to the Phorum!
For the knobs check with Gary at http://oldradioparts.com (looks like he's closed until 3/11).
Thank you, Nathan! I will reach out to Gary next week...
Philco Knobs & Pushbuttons (original)
David Frush (original and NOS knobs, including many for Philco sets)
Julie McCall - Original knobs for Philco and other radios.
Kelton Trammell - Original knobs for Philco and other radios.
Mark Oppat's Old Radio Parts
Mike Koste - Gobs of Knobs
Here at the Philco Phorum we have a Resource section has listed parts and services available for Philco sets.
Personally have had dealings w/ Julie and Mike both are top notch!
Welcome to the Phorum.
Much appreciated, Terry
Or you could keep your eyes open for a smashed early 50s Philco plastic radio or junker radio-phono combo, many of those use the same style of knobs.
There are currently 9671 online users. [Complete List]
» 1 Member(s) | 9670 Guest(s)
