Ham Radios
I'm sure there are some ham radio operators here On the Phorum. Does anyone have any recommendations for a decent but not expensive handheld ham radio transmitter/receiver? My stepfather has a big setup, but due to his age and health issues, needs something small and simple. Thanks in advance for any suggestions.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
https://baofengradio.us/baofeng-uv5rv2-black.html
Have hear these are pretty good and you can't beat the price. Setting up the memories is tricky so you may have to help out.
I have to agree with that. You can't beat Baofeng for analog FM. Use CHIRP to program them, it's free.
Clinton VE7KNL
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
