Philco 8974
I have just found a Philco 8974 at a yard sell for $2, but i am unable to find any info on it.
I would love to get a schematic for it.
[Image: http://willysworld.atspace.com/FTP/philco8974.jpg]
(edited by site admin to show picture)
"8974" doesn't seem like a good number and the pic isn't showing. Is it a radio?
i looked at it wrong its a G974. i have found some info on it now
That's odd. The picture was showing last night - on my end, anyway.
Anyway, glad you figured out the correct model number. It's a 1959 model, btw.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
