aligning philco radios
there is a pdf download somewhere on aligning philco radios can some one guide me to that
Benny
http://www.silverslingshot.com/PDFFILES/...s_1937.pdf
Think this is what you wanted.
That looks like a very useful doc. Are there more - other brands?
Not sure Russ, I haven't looked very hard.
I might do a little looking around to see if there is more out there.
"change of IF Peak" on actual document page # xxiii,,, hummm  interesting!
i am not really sure how to use the index, based on my model 46-1226,, as in where inside the manual is the info for my radio?
The publication includes radios up to 1937. Your 1946 radio wouuld not be in there.
Alignment info for your radio should be in the service bulletin found on the audiophool site.
You need the djvu plug in or reader to view the document.
91H Code 126 Restore
