46-1201 Bing
I have a 46-1201 and was wondering if there are instructions or if anyone could tell me how to get this thing apart? I see no way to get either the record player or the radio chassis out. Thanks for any insight you can provide.
Gregb
Never mind, I found the spring loaded catch that holds the top on.
Gregb
91H Code 126 Restore
