Help info about Model 95
Hello, I have this old Philco Model 95 wich I can't find any info, photos, specs or pricing.
I've taken some photos so you can have a look, any small info is appreciated.
Thanks.
[Image: https://i.imgur.com/mhrP3lp.jpg]
[Image: https://i.imgur.com/hSXax7w.jpg]
[Image: https://i.imgur.com/Fov2Vl0.jpg]
[Image: https://i.imgur.com/wA0fLXf.jpg]
[Image: https://i.imgur.com/26natez.jpg]
Welcome to the Phorum!
Icon_wave
Not a lot of UK Philco info here but hopefully someone might have something for you. Some general info: http://philcoradio.com/phorum/showthread.php?tid=15019
Hi and welcome to the Phorum,
Unfortunately there is much info here for the UK models. There is a US model 95 but it's nothing like what you have.
You might try over here:  https://vintage-radio.net/forum/index.php
Just from it's appearance I'd guess it's from late 50's or early 60's.
Here's the service info for the turntable:  https://www.vinylengine.com/library/garrard/rc210.shtml
It's from 1960.
Thank you guys, I'll keep trying to find more info
There are currently 8615 online users. [Complete List]
» 1 Member(s) | 8614 Guest(s)
