Philco 39-6
Ron,
1. Type of wood I'm dealing with?
2. Color of lacquer to use? Highlights?
3. Proper grill cloth pattern?
4. Any decals?
David Woodward
WildDog Wrote:1. Type of wood I'm dealing with?
Walnut veneer.
Quote:2. Color of lacquer to use? Highlights?
Medium Walnut, with either Extra Dark Walnut or black lacquer on the edge and bottom trim.
See here to get the idea:
http://www.philcoradio.com/gallery/1939a.htm#a
Quote:3. Proper grill cloth pattern?
I think it should have the "Ribbed" pattern (#14 from Radio Grille Cloth Headquarters).
Quote:4. Any decals?
No, since the PHILCO trademark is on the dial scale.
Thank you Ron.
There are currently 10565 online users. [Complete List]
» 3 Member(s) | 10562 Guest(s)
