70 cathedral speaker baffle/plate?
I don't suppose anyone out there has an accurate tracing of the sort of heart-shaped baffle or plate that the 70 loudspeaker mounts on? I have a good playing set but the repairman or whoever reworked it, did not install that part in the cabinet under the speaker. I would like to make a repro for eventual installation. I would assume an original or repro would be quite expensive. Thanks, Tom
Hello Tom:
Here's a link to a reproduction "cloth frame" for a Philco 70: <!-- m --><a class="postlink" href="http://www.retro-tronics.com/itemDetails.php?shortDesc=Philco+70+Grill+Cloth+Frame">http://www.retro-tronics.com/itemDetail ... loth+Frame</a><!-- m -->
I'll have my Philco 70 apart in a week or so and could trace my tattered cloth frame.
Allen
Thanks. Well the ad you linked to has them selling them for a dollar less than they are selling them on fleabay. Looking at photos of the insides of the radios in listings, they look to be either a tan natural finish or black. Some sort of thin board material? I was hoping to make a one-off repro from some materials here, and save the money with my labor. But if nothing turns up I will just have to buy one of those I guess. I am not sure why the restorer left one out of this 70 that I have but it does not seem to have much impact on sound, I covered the gaps and hear little difference. I guess it does hold the grille cloth flat though. And prevents the pilot light shining thru the grille cloth in the dark!
BTW I learned a valuable lesson about 80 rectifiers last night. Apparently some of the sockets are sloppy. I had the tubes out to test and was working in dim light. I was sorta putting the 80 back in the radio by feel. Well the holes were sloppy enough that the tube slid right in 90 degrees off! When I powered up, POP! went something, and lots of smoke rolled out. That made me feel really bummed. Foolish mistake. One of the under chassis replacement 10 UF filters had blown. I disconnected it and it still played good with one filter cap! Not alot of hum like I expected. But I got two new caps on the way. And will mark the dang tube for alignment!
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
