Philip 66B Cathedral grill cloth
Is there any source for this?  The old one is too beat up to use.
Jim
Yes!
http://www.radiodaze.com/grille-cloth-05-item-grc05/
by the way, the thin green stripes should be vertical, not horizontal as shown in Radio Daze's picture.
But that's for the Philco 66.
I'm sure the Philip 66 uses something different.
Just stop at any Phillips 66 dealer. Icon_lol
[Image: http://images.all-free-download.com/imag..._70166.jpg]
Get yer kicks... Icon_smile
  1. Dang! They don't have Phillips 66 out here in CA any more. I think I will stick with Philco 66B.
And thank you Ron for the quick answer regarding the grill cloth.  When I get my computer up and running again, I will scan the original fabric and the replacement from RadioDaze and post them. There is a difference but  I guess it is close enough.
Jim
Eico 232 VTVM Schematic
There are currently 9333 online users. [Complete List]
» 1 Member(s) | 9332 Guest(s)
