Philco Hippo 46-620 Code 128
Threads: 10
City: Bloomington, IL
Anyone know where I can get a schematic for this one? Not on Nostalgia Air.
This version has the 50B5 and the 35Y4
Joe Miller
Threads: 76
City: Winter Haven, FL
I can find no reference to a 46-620 on ANY site. It's not a 46-420?
No such thing as a 46-620.
Threads: 19
City: The Motor City,Detroit MI
I have the Riders schematic for both 46-420 and 48-460 Hippo models. Neither has the 50B5. Are you sure someone didn't just stick a 50B5 into the chassis before you got the radio? Can you post a picture of the chassis?
Threads: 3
City: Chesapeake VA
Well I dunno if it should have a 50B5 or 50C5 but was common in that time period for same sets to have different tubes(of course for Philco depends on code number). If the audio output transformer is connected to pin 5 it uses a 50B5, if on pin 7 it should have 50C5.
Assuming a 46-Something, would be impossible(at least from factory) to have a 50C5 as that tube wasn't introduced till 1948.
Tom
(This post was last modified: 05-09-2018, 03:39 PM by 35Z5.)
Threads: 569
I have seen on other radios output tube swap at the factory (do not remember if it was a Philco). And swapping halves of rectifier tube is common also.
Threads: 3
City: Chesapeake VA
As easy as looking on RM, the 46-420 code 128 does indeed use 50B5 & 35Y4... No schematic though..
Except for socket & their wiring connections won't be any different than one that uses 50L6 & 35Z5.. Same tubes different package..
https://www.radiomuseum.org/r/philco_46_...e_128.html
Tom
Threads: 268
Reminds me of an old radio show called "Let Pretend"
Figure out which tube (s) it uses as Tom mentions and renumber the diagram to match.
From what I remember the big difference between the runs is the spkr
some used pm vs electrodynamic. Not a big deal.
Threads: 30
City: Wellborn Florida
Looking at the bottom of the audio output tube socket and determine which pin goes to the output transformer. If its is pin2 tube should be 50A5 if pin3 tube should be 50L6. David
Threads: 268
There's a major differences between the 50A5 and the 50L6, 50A5 is a loktal base tube the 50L6 is an octal. They use two different sockets.
Threads: 54
I have three of the Canadian versions of a 46-420, or their successor models, none of which used a 50B5 tube, however two have a XXD/14AF7 mixer oscillator, and two IF amplifier tubes, whilst the third uses a 7A8 octode converter tube and has a tuned RF amplifier stage ahead of it, and is followed by a single IF amplifier tube, I don't think that any of mine used a 35Y4, or a 50A5 but I will have to look. I thought it was some of the later versions of these that used 7 pin miniature tubes, not the earlier ones? It seems that these sets were like the 1201s, they were slapping them together with whatever parts they could get in a given week.
Threads: 3
City: Chesapeake VA
(05-09-2018, 10:26 PM)Radioroslyn Wrote: There's a major differences between the 50A5 and the 50L6, 50A5 is a loktal base tube the 50L6 is an octal. They use two different sockets.
Agreed, plus OP mentions set has 50B5 which is a miniature tube, no chance it has a 50A5 or 50L6...
Tom
Threads: 271
City: Wilsonville
State, Province, Country: OR
Joe, some photos of your set's chassis and cabinet might help folks help you.
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
