Working on Philco Model 37-623-J
Threads: 1
City: Las Vegas Nevada
Hi all,
I am recapping a Philco Model 37-623-J Battery Console . Can anyone tell me the voltages of the A,B,C batteries that I need for this radio. I am looking for a battery eliminator that would run it. Also if anyone has a clear schematic of this radio that would help as well. Thanks in advance for any help you can give me.
Threads: 69
City: Kansas city, MO.
Welcome, If you have a DjVu reader on your computer you might check here.
http://www.audiophool.com/Philco.html
Threads: 268
Hi and welcome,
As a matter of fact I can. that would be 2v,90v,135v, 3v, and 9v.
(This post was last modified: 05-16-2018, 11:56 AM by Radioroslyn.)
Threads: 1
Thank you for the quick reply. The Schematic is great and will help a lot.
Threads: 1
Hi Terry,
Is there any type of battery eliminator that I can find for this radio to cover those voltages?
Threads: 242
City: West Bend, Wisconsin
Threads: 268
Depends on your skill level. If you conformable building one. It's not very difficult would use a couple of dry cells for the C voltages. If you have a few spare parts you could build one for $30 or so. I think AES and or RD sells battery eliminators.
(This post was last modified: 05-16-2018, 02:14 PM by Radioroslyn.)
Threads: 1
Thanks again Terry
Threads: 268
Greg is are expert on eliminators [Image: http://philcoradio.com/phorum/images/smi...on_lol.gif] and have want to eliminate him on numerous occasions[Image: http://philcoradio.com/phorum/images/smi...on_lol.gif] .
If you have so time to kill have a look at this http://philcoradio.com/phorum/showthread.php?tid=17660 you might find it interesting.
(This post was last modified: 05-16-2018, 05:45 PM by Radioroslyn.)
Threads: 20
City: Tiffin, Ohio
Hi Radiofanatic, I have the Philco 38-643B which runs on the same batteries as your 37-623J. I use the ARBEIII battery eliminator and it works very well on my radio. I have a 7 pin socket connected to the ARBEIII for the B & C voltages and the 2 Volt leads connected to it and set to 2 volts. Ken
Threads: 1
Threads: 242
Ha! I know, Terry, I have been brutal on you with some of the challenges I've encountered. No, make that ALL of the challenges I've encountered! But you have the patience of a saint, my friend, and for that I'm forever grateful!
Hardly an expert on battery eliminators but I do use the ARBEIII on my Atwater Kent models 20 and 35 and it works great.
Threads: 1
Hi Ken, I finished restoring my philco 37-623-j and have an ARBE-III . Which tubes are the A+,A-B+,B-,C+,C- connected to in the radio. can you draw me a diagram to explain how to hook it up. I am a bit confused. I dont want to blow up the tubes with the wrong voltages.
Thank you in advance
John
Threads: 268
Hi John,
Do you have the original power cord and plug? If so if you can dig up an old 7 pin standard tube socket ( used for 2A7,6A7, 59, and 1625 I think) it should mate up to it.
I had a similar set a 37-33 just no sw coverage.
Threads: 20
City: Tiffin, Ohio
Hi John, I'm at work currently but I'll get a picture later this evening of my 7 pin tube socket connected to my ARBE III and the schematic of the 37-623J as the battery connections are the same as my 38-643B. The A+,A- terminals are set to 2.0V on the ARBE III before I connected the A+ & A- leads from the radio battery wire harness and the 7 pin plug is inserted in the socket that is connected to the ARBE III for the B & C voltages and it works great. Ken
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 3164 online users. [Complete List] » 1 Member(s) | 3163 Guest(s)
