Philco radio grill
Hello, I'm new on here and I have a question I hope someone can answer for me. I just picked up a Philco 49-506 wood cabinet radio that is in really good shape. The only thing is the plastic grill is a little rough.i have tried cleaning it and it still has stains and some deep scratches. Is there anyone out there that would have a nice grill for sale? Or is there a way of reconditioning one? Any info is greatly appreciated
Hi;
  I think that the grilles in those are made out of polystyrene plastic, so a good bath in warm water and a little laundry soap should help, you will have to remove the grille from the cabinet naturally. It won't remove the scratches of course but it should make them less noticeable, unlike Bakelite polystyrene won't go dull from standard cleaning products. The only way to remove scratches in plastic is by wet sanding with extremely fine sandpaper, in a succession of steps into finer and finer grits, followed by by a plastic polishing compound such as Novis or one of the polishes used for auto paint.
Eico 232 VTVM Schematic
There are currently 7451 online users. [Complete List]
» 1 Member(s) | 7450 Guest(s)
