38-690 Refinish June Update
#31
Sure, you can do it that way - by hand. I use a 3M polishing compound for lacquer and a pneumatic buffer with a foam pad.
A fresh, gloss lacquer finish is too shiny unless buffed out and the process will level other imperfections as well. Normally I will wet sand first with ~1500 wet/dry.
Beautiful X2...
DO mine now, Icon_lol
Icon_smile
Kirk,
Thanks for the compliments.
We don’t live too far apart LOL Icon_biggrin and I know you have one waiting.
I need to get through mine first. Right now my head is spinning trying to figure out how to finish it off. I like the gloss look, but was it really glossy when new? Then there is the fact that I don’t have the fancy orbital sander yet, so now what? Icon_crazy
Don’t get too much in Kutztown Icon_biggrin
Tony
#34
Tony,
I have already bought 4 radios and I have not even gotten there, Icon_lol
Thats about all I am getting unless I find a real nice addition or a Halson.
Icon_smile
I think they were all glossy.
#36
I found this Mohawk product on the Mohawk website. I don’t know if anyone has used this or a similar product. Looks to be right up my alley. Let me know what you think.
http://www.mohawk-finishing.com/catalog_...ictNbr=251
They also have a level 2 product.
http://magicwoodrepair.com/items/Rubbing...s/list.htm
Tony
#37
Well the cabinet is finally done. I did rub out the finish using 1000 and 1500 grit wet sanding, followed by Mohawk Stage 3 Poly Buff. There were three grits of Poly Buff, Medium, Fine, and Extra Fine. Each step was followed by the next till done. I gave the whole cabinet a coat of OZ Cream Polish after the rub down. Here are the results. I plan to have better pictures once it's together shortly.
I will say this has been quite a learning experience, and a gloss finish will certainly bring out any flaws that exist. The main thing is that I learned so much by doing this project, that I won't hesitate to do another of this magnitude, and make improvements too.
Tony
#38
It looks great.
#39
I wouldn't kick that one out of my living room! Beautiful job!!!  Icon_thumbup
#40
Gee Wizz  It looks better that when it left the Philco factoy!   Icon_thumbup Icon_thumbup Icon_thumbup
#41
Super deluxe, a real beaut of a job.
Beautiful!
#43
Absolutely Gorgeous!!! Fantastic job!
Gregg Icon_thumbup
There are currently 8811 online users. [Complete List]
» 1 Member(s) | 8810 Guest(s)
