1930 Philco 20B Cathedrals
Threads: 91
City: Jonesboro
State, Province, Country: AR
Last September, I picked up an empty but otherwise in excellent condition, Philco 20B early version Cathedral cabinet. I have since completed it with a chassis and speaker.
If all goes as planned, this coming Thursday, I have a fellow collector and Facebook friend dropping off a late version 20B Cathedral for me to restore for him.
I was contemplating working on them side by side.
I looked over the schematics briefly for both that Ron posted here at the Phorum, and downloaded them.
One question I have: The Capacitors in the Capacitor Block (27). Since they are marked with polarity, I assume electrolytics are called for. Are 450v caps sufficient?
Also, If I have problems find the exact value, are 2uF or 2.2uF substitutes OK?
My primary experience is in mid to late 1930s Philcos, so I'm wandering into somewhat unfamiliar territory with these 1930 models.
Any tips, advice and help are welcome and appreciated.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Jeff
Use film rather than electrolytic. There's plenty of room inside the can, and they will last much longer than electrolytics. I would use 600/630 WVDC but others will chime in with their opinions.
2.2 uF is a good sub for 1.5 uF. You can get 1 uF to replace the original 1 uF units.
I posted those schematics before film substitutes were known to me.
Threads: 91
City: Jonesboro
Thanks Ron.
Based on your recommendation, it looks like I will need to put an order in. I don't think I have all those values in stock.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 72
City: Linn Creek, MO
Just my 2 cents, fairly large value film capacitors are available at a reasonable price. I would go with 1mf for terminals 1-2, 4.7 for terminals 1-3, 4.7 for terminals 1-4 and omit the capacitor on terminals 2-6
M R Radios C M Tubes
Steve is right, especially about omitting the capacitor across terminals 2 and 6.
Threads: 91
City: Jonesboro
(02-07-2018, 12:45 PM)Ron Ramirez Wrote: Steve is right, especially about omitting the capacitor across terminals 2 and 6.
So, please help out a relative newbie- what function does the cap between 2-6 do, and why omit it?
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 569
Cap in this position is supposedly improves the ripple by producing the opposite-directed ripple +90 degrees vs -90 degrees, so they cancel each other.
Its kinda counter intuitive.
The inductor alone is sufficient plus the cap in position 4-1 can be increased quite a bit without fear of damaging the 80 tube to have much better effect on the ripple.
Threads: 91
City: Jonesboro
(06-03-2018, 09:08 PM)morzh Wrote: Cap in this position is supposedly improves the ripple by producing the opposite-directed ripple +90 degrees vs -90 degrees, so they cancel each other.
Thanks!
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
I'm ordering parts and doing preliminary checks on both chassis. On mine, it looks like the 1st section, between pins 1-2 on the candohm is dead  . What wattage should I look for to replace this section?
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
I'm getting a Philco 66S from radiowilbur, so I'm hoping he can round up a replacement part, but just in case, knowing the wattage for a replacement would be helpful, thanks.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Bump. Anyone know the needed wattage for the candohm? I can't find any documentation on this part. Thanks.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
Total dissipation is 2 1/4 watts would use a 5 or 10w unit.
Threads: 91
City: Jonesboro
Thanks Terry.
I'm working on the bakelite blocks. I've done many of these, and it's going smoothly. While working, I'm also checking resistors. I had to disconnect one end of the lower of the 2 dark gray dog bone resistors in this pic in order to flip the block over. It checked out at 800K, and should be 500K, so it needs to be replaced. My question is, what wattage is it? My experience tells me a 1W will replace it, but I wanted to confirm. Thanks.
[Image: https://farm2.staticflickr.com/1743/4087...73dd_k.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
1/2w is fine for both of the 500,000 ohm resistors.
+1 what Terry said.
For what it's worth, all of the dogbone resistors in Model 20 are 1 watt. Some, such as the 500K, are overkill. Philco simply did not have anything smaller in wattage at the time.
1/2 watt resistors did not start to appear in Philco sets until 1931.
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
There are currently 4511 online users. [Complete List] » 2 Member(s) | 4509 Guest(s)
