Tropic 53-960 restoration
Threads: 569
15-minute soak in lacquer thinner didn't hlp either.
Will soak overnight.
Tar is going to laugh at a mere 200 degrees. As I said previously, sometimes the tar is on top, sometimes on the side. And sometimes both.
Good luck.
Threads: 569
I followed the recommended 200F Arran suggested
Threads: 54
Mike;
In truth I can't remember whether it was 200 or 250, but you don't want it too high or the cardboard will burn. I personally like the idea of putting the top back on the metal can even if the cardboard sleeve goes over top, it adds some extra structural integrity to the cardboard, and it's easy enough to join the two sections back together with aluminum duct tape if the cut is clean.
With regard to that phono jack I don't know what they were up to there, the usual method is to feed the signal into the grid of the 1st audio tube, or the top of the volume control. I don't know what they were up to in connecting the center of that jack to the plate of one of the power output tubes, and I've never seen a choke involved with a phono jack instal before, maybe they had some other intended purpose, five will get you ten it was a Ham operator that did it.
On those molded paper caps I think that Dennis Carter did drill the actual capacitors out of the plastic shells with a twist bit in a battery powered drill, they looked like those Sangamo "Little Chief" caps to me with the bright coloured shells. I don't know if the Bumble Bees are molded any differently, but one thing I do know is that they were no better then the run of the mill Aerovox waxies, unlike the Solar "Sealdtite" brand ones which are one of the few that are usually still functional.
Threads: 569
Well,
I soaked it 24 hrs. Tonight I pulled the pickle out of the brine, grabbed one of the twist tabs with pliers, and the shell with my hand, pulled and the cap came out with the juicy "chwuak!"sound.
Black tar.
Removed most of it but decided to soak more to remove the rest.
I like this method more as gripping hot capacitor while trying to work fast as it is cooling fast is even less enjoyable.
...that's what heavy gloves and pliers are for.
P.S. Congratulations. I would not have thought soaking would be successful, given that the shell is foil over a very thick paper material.
Threads: 569
Ron
It's permeable, plys open unfoiled end at the lower flange. It came out without much effort at all, plus the thinner did not make the paper warp.
Here it is.
Threads: 569
Received 0.0056uF caps to restuff 0.006uF Philco tubulars. These proved to be the most stubborn caps yet: I do not know what kind of compound this is they used for the plgs, but it doesn't melt. I broke the leads on one, and ended up crushing the p!ugs with a hammer, damaging one end so I had to trim the tube.
The second cap I approached differently: I held one lead in a vice and pulled the other lightly with pliers: after 5 minutes of heating the plug came out. The other end didn't fare as good: I ended up crushing this end too, though it worked better this time. Spent an hour for two caps, and I have another two of the same.
Threads: 54
Mike;
I've run into tubular paper caps like those before, they were made by a company called "Good All" and had some sort of putty in them that does not melt with heat. "Good All" in spite of the name, does not have a good reputation, a guy who fixes TVs on You Tube calls them "Bad All" and he lives in an area where even paper Aerovox caps seem to be good after 60 years.
I never did try soaking them in lacquer thinner, but I don't really have any equipment that used "Good All" caps as OEM components, plus they are from the 1950s and therefore too new to bother with.
Threads: 569
I take it, Philco might use re-labeled caps then? These are the only ones in the whole radio that behave like this.
There are different waxes, those brown that melt more readily and those greyish-brown or grey that melt not as good, but all do melt and come out without major problems. These are 6nF 450V caps and the only type I ever encountered using this type of putty or whatever that is.
Threads: 54
Mike;
I don't think that Philco was making their own capacitors by this point, it seems like they were contracting this out to outside suppliers who would label the caps as Philco brand, with their part numbers, and so forth. I can remember taking one of those cap and choke assemblies apart in one of their transformerless sets from the 1940s and found a Sprague brand cap inside of the cardboard tube they used as a coil form, and clearly it left the factory this way. Whether Philco always used Sprague as an outside supplier I don't know, maybe by 1953 they were sourcing from whoever would supply what they wanted at a given moment, maybe "Good All" was one of them?
Threads: 569
06-16-2018, 07:49 PM
This is how the plugs from the caps look after extraction. They havent lost the shape in the least bit.
The chassis after tubulars recap.
Threads: 569
The twistlock cap. Being glued together. Will dry up tomorrow.
Threads: 69
City: Kansas city, MO.
Good job Mike.  It should be a good playing radio when you're done.
Threads: 569
One more twistlock and hopefully this will be it. This one also isn't in a cadboard shell so maybe it'll be easier. But I hate that phenolic panel they are mounted on.
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
There are currently 3388 online users. [Complete List] » 1 Member(s) | 3387 Guest(s)
