Threads: 1
City: Hagerstown
State, Province, Country: Maryland
Help! Can anyone tell me exactly where the springs on the model 87 dial cables anchor?
I have the radio electronics rebuilt including re-capping and it works, but the dial cables
have me stumped.
Threads: 214
City: Seattle
State, Province, Country: WA
Threads: 114
City: Sneedville, TN
Not sure if the 87 and 89 are similar in stringing, but I found this thread on Antique Radio Forums, hope it is helpful. There are a couple of pictures a little way down that may help. http://www.antiqueradios.com/forums/view...p?t=193224 . I have also used braided fishing line for a replacement for dial cord, just buy the thickness that looks close to what yours was at a good fishing tackle shop. Also, Radio Daze sells dial cord, although I'm not sure of its size as I have never bought any. Good luck to you.
Threads: 268
The 77 and 89 are different than 87and the 95. It has two worm gears one at the front and one at the rear connected by the tuning shaft. At one end of each gear there is a peg. A loop at the end of each cord (there is two cords) slips over the peg. The cord is wound around the gear (would start with the rear gear) and then it is fitted over the dial drum thru the small hole and a spring anchors the cord to the inside of the drum. Same w/the front cord but it's would in the opposite direction. One cord pulls and the other pushes which in turn rotates the drum. GL they are a pita to replace. One tip is if you have a good cord measure it to get the correct length from loop to loop. I'm pretty sure there are the same length.
Hope this helps and have fun making up new bad words. [Image: http://philcoradio.com/phorum/images/smi...wisted.gif]
(This post was last modified: 06-09-2018, 11:08 PM by Radioroslyn.)
Threads: 8
City: Wood River, Il.
When I had to replace one of the cables on my 95, 2 or 3 years ago, I think I found some very small cable at my local bait and tackle store, but would not swear to that. I can’t remember, either, what I used for cable ferrules. As Terry said, though, it is a PIA, and requires lots of patience and a good vocabulary! (I sure found just how limited mine was!) One thing I found handy in the process, though, was the use of the small Vicegrip pliers to act as a 3rd and 4th hand. As Terry stated above, only one cable at a time “pulls” the dial drum at a time, depending on direction of the shaft turn, while the other just maintains tension on the drum, as it unwinds. They should both be taut at all times, with no slack in either cable, or it will all come unwound into a small rats nest.
Perhaps, braided nylon fishing line would work, but I was afraid that it would stretch, over time, requiring a complete do over. I didn’t want to go thru this again. Good luck, and have fun with it.
Chris H
N9WHH
Threads: 268
I'll mention in passing one 1st I did was back in the 70's and didn't have a source for metallic cable. I ended up using steel wire used for hanging pictures. It was fairly easy to work with and could solder loops on the ends. I don't remember the ga but would guess abt 18 or 16.
Threads: 19
City: The Motor City,Detroit MI
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
