McMurdo Silver Masterpiece Saver/Adaptor
Here is an option for saving all of those McMurdos that have had the Jensen Super-giant and/or the amp/PS sent to Asia.
https://www.russoldradios.com/blog
Now All I need is someone to move it off of the bench Icon_rolleyes
Russ
Great, Russell! Fantastic work performed. I'm delighted with your style of restoration.
