42-1009 Decals
Hi, does anyone have a picture of the decals for the 42-1009? I need to know where they go and what they are supposed to say. Thanks!
Sorry Jeremy,
I don't have a 42-1009 but I can probably look up which decals you need. Give me a day or so.
Thanks, Ron! I've got a vague idea that they should be curved and from left to right say something like "Tone" (or "Bass"???), "Volume", "Phono-Bands", and "Dial Tuning" but obviously I'd like to be certain before I slap anything on there. Thanks for your help!
I believe you are correct.
I don't have one to look at, as mentioned before. But I think you will be OK with decal set DCL-41-608 from Radio Daze. This includes "BASS" (with curved arrow), "VOLUME," "DIAL TUNING" and "PHONO-BANDS."
The decals apply, from left to right, in the order given above (BASS - VOLUME - DIAL TUNING - PHONO-BANDS).
Thanks, Ron. I've used Radio Daze before, and I'm pretty happy with their products. I'll pick up this set on my next order from them.
There are currently 11428 online users. [Complete List]
» 2 Member(s) | 11426 Guest(s)
