Eico 324 RF Output cable
I picked up a nice old recapped Eico 324 Signal Generator, but without the  RF output cable. Does anyone know where I can purchase one that will work for this? Is there a way to convert it to some other style? What are my options? Thank you for your input in advance.
Gregg Icon_thumbup
It probably used a shielded (not coax) cable with an Amphenol connector, basically like and old fashioned microphone. There are available, at least NOS and used ones are, look it up on fleabay, or on Mouser or Digikey's sites.
What you are seeking is a Switchcraft 2501F. You could swap it over to another style of connector like a bnc or so-239 but if you don't have any other cables that already have these connector on them I wouldn't bother.
Thanks Terry!
Gregg Icon_thumbup
E-Bay sell them,,,,just like NOS
Eico 232 VTVM Schematic
There are currently 9175 online users. [Complete List]
» 1 Member(s) | 9174 Guest(s)
