Neutrowound Replacement Caps/Shields
https://www.russoldradios.com/blog
In between smoke, fires, heat and a million other projects - -
Making replacement caps for a 1926 Neutrowound receiver.
Russ
Another impossible job made possible.
Icon_clap Icon_clap Icon_clap
Looks exactly like the original...super work!
Very impressive Russ Icon_thumbup
Copy of post on WOOF Forum - - -
"After" picture added.
How thick? Well, that will vary a little and trimming of the flashing will cause a bit of variation at the base. I was aiming for a match to the original and without a micrometer measurement, they appear to be similar in thickness and strength ( I just inserted them into the radio and one was tight). The nickel could make them thicker (and of course does) but there is no reason to plate on so much nickel that fit is a problem.
The copper solution is acid-copper (basically a PH negative solution of copper sulfate).
Russ
Most impressive, Russ!
There are currently 9895 online users. [Complete List]
» 1 Member(s) | 9894 Guest(s)
