Philco Power Transformer 5785
I have a Philco 5785 transformer and wonder where it was used. It does not have the 32- prefix and is fairly small.
1937 Philco parts catalog lists 5785 as a Power Transformer for Model 4.
Thank you.
The speaker table error?
Philco 70 antenna lead
There are currently 6954 online users. [Complete List]
» 1 Member(s) | 6953 Guest(s)
