Threads: 1
City: L.A. Calif.
I'm new to the phorum. Just wanted to say thanks for all the help and answers I was able to
Get from reading all the experiences you all have shared and discussed. Thanks Ron for your
Detailed description on the tuning drive assembly. I really had a time with that D ring wire. This
Is my first restoration really had fun.
Thanks again Paul
Welcome aboard, Paul! But don't thank me on the dial drive info, thank Richard Hines who supplied the text and photos. I just posted it all on his behalf.
For those curious, the thread in question may be found here.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
Threads: 1
City: L.A. Calif.
A photo of my 650 H
Threads: 566
Welcome Paul!
Threads: 268
Hi Paul and Welcome,
I've got it's big brother.
[Image: http://philcoradio.com/phorum/attachment.php?aid=11710]
Your 650H is nice looking!!!!
Threads: 1
City: L.A. Calif.
(03-21-2017, 10:56 PM)Radioroslyn Wrote: Hi Paul and Welcome,
Thanks Terry, that's a very nice 660 L (right?) its only the 2nd one I've ever seen.
And thanks for the welcome, Paul
Threads: 268
Yup 660L. I've only seen one other too, on the net and I think it's over on the left coast.
Threads: 91
City: Jonesboro
State, Province, Country: AR
Nice 650H! I'd really like to find one of those someday! I really like the lyre design! I have a set of lyre back chairs this Radio would look good with in the same room someday!
If they're rare, though, if I was ambitious enough, I might try to make my own cabinet.
I do have a 650X unrestored that looks pretty decent. It's an 8-tube if I recall, so it should be pretty decent sounding and a good performer!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 40
City: Sanger, CA
Here's me 650 MX, that I've had for about 30 years. Found it in the local paper back then for $50 and restored it, as the finish was too far gone to save. That is the original speaker cloth! Lucky for me, as reproductions back then, weren't readily available. Seems to be a fairly uncommon model. Love that trap door dial on the 650 series!
[Image: http://www.surfacezero.com/g503/data/500...0_MX_a.JPG]
[Image: http://www.surfacezero.com/g503/data/500...650_MX.JPG]
(This post was last modified: 11-03-2018, 11:16 PM by SteveG.
Edit Reason: add text
Threads: 268
Very Nice!!!
I was hoping to get busy on refinishing my 660L but the weather this spring/summer/fall was not very conducive to spraying lacquer. Spring is coming!!
(This post was last modified: 11-03-2018, 10:49 PM by Radioroslyn.)
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
RCA T62 is playing.....
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
Thank you Rod.
Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM |
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM |
There are currently 2680 online users. [Complete List] » 2 Member(s) | 2678 Guest(s)
