2nd IF Transformer Question
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Good morning all, I’m working on my 60L and have been going though the transformers. Yesterday I rewound the primary on the oscillator: The antenna looked and tested great. The 1st IF tested to the specs on the schematic, but the 2nd IF tested bad unless the schematic is incorrect. It shows values of 34 ohms and 85 ohms and mine tests out at 35 and 46. Is the 85 on the schematic incorrect or is the one winding bad? If it is bad can I rewind it? If so what size wire and how many turns? Thank you!
Gregg
Threads: 112
City: Medford OR (OR what?)
I would test it in operation prior to doing anything else. It is probably OK. They are tough to rewind.
Threads: 22
City: Kewanee
Thank you sir, that’s what I will do then. What symptoms would I see if it is not great?
Gregg
Threads: 112
It will either work or it won't. Won't meaning - No or very low level to the 2nd detector stage - unable to tune.
That kind of winding on a secondary can sometimes have corrosion problems but there isn't usually much current so they don't burn open like a primary. SOMETIMES the tuning (caps) can be the problem.
Threads: 569
It is rarely n RF coils that there's continuity and it is bad.
Threads: 22
City: Kewanee
Ok, sounds good. I’ll see how it does once I get it all back together. Thank you both for your input.
Gregg
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 3194 online users. [Complete List] » 1 Member(s) | 3193 Guest(s)
