Please Help Identify This Dial Face
Hi, All.
I have an old dial face that I forgot about and don't remember which radio I was canabalizing parts from.... so I don't know describe it to sell.
It was so perfect I just couldn't throw it away! (SEE PHOTOS). The lettering is gold color. I have the backing plate for it too.
I am pretty sure it was a 1940's Philco radio/phono console... but I am just not sure.
Can anyone tell me if it is a Philco dial face and which model (or models) it was produced for?
Thanks!
Harold,
Radio Daze shows the 27-5935 dial scale for 46-1209 and 46-1226 radios.
Carl
Northern Panhandle, WV
There are currently 10410 online users. [Complete List]
» 2 Member(s) | 10408 Guest(s)
