Threads: 76
City: Winter Haven, FL
Recapped, changed resistors, replaced wiring, and aligned. It working great. Put it back in the cabinet, powered on, and after the tubes warmed up, got a hum. Removed chassis, and still have a hum. I can still pick up stations. Hum does not change with the volume. Rechecked the wiring, paralled new filter caps, no change. When I prod around the 42 output tube, hum volume seems to vary. Stuck another 42 in there, same as first one.
Since it worked before I put it in the cabinet, I focused my attention on solder joints and wiring. Nothing wrong there. And since the hum doesn't change with the volume, I thought it might be easier to find. But the volume pot is on the antenna lead-in.
Any ideas?
Pat
Threads: 5
City: Burlington
State, Province, Country: Wisc
Hello Pat,
I am currently restoring a 40-200 and performed everything you did, caps, resistors... Worked well for a day or two and started getting a hum. Caps are all good. It ended up being the phase inverter tube socket. I cleaned the socket using 90% alcohol and welder's tip cleaning brush. Plugged in the tube and bingo, no more hum.
On another radio I restored the problem was a solder joint on a tube pin. I re-soldered it by placing the tube upright, heating the pin and letting the solder get sucked up into the pin.
You may also want to check all of your solder joints. I use a chopstick to poke around under the chassis.
Denis R.
(This post was last modified: 11-24-2018, 10:58 AM by drrenaud.)
Threads: 91
City: Jonesboro
State, Province, Country: AR
Try checking the rivets to the tube shield bases, make sure the tube shield is making good contact with the base, and the base has good contact with the chassis.
Also, I have a 45C I worked on some time ago, and it had a loud hum 1st time I powered it up. It turned out the common wire to the electrolytic filter caps on the ground side had a break in it. It was a solid wire, and the break was inside the insulation, so it wasn't visible.
As soon as I replaced it with a new wire, I was up and running.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 268
I had an 84 a while back w/that problem and ended up being a bad rivet connection on the 42 socket.
YMMV
Threads: 76
All good tips. Thanks. I'll go see what I can find.
Threads: 76
Well....Checked all solder joints, cleaned all tube sockets, by-passed almost all wires with a jumper, one at a time. I found one loose wire, resoldered it, but the only change was prodding the entire chassis now has no effect at all. Thought I'd post the schematic. Maybe there is an error in it somewhere.
[Image: https://i1367.photobucket.com/albums/r79...nbvfhn.jpg]
Threads: 30
City: Wellborn Florida
Maybe this will help Beitmans has the parts layout under the hood.
Threads: 18
City: Cromwell
State, Province, Country: CT
I repaired on of these with the same hum. It was the rivets to 77 tube shield base. I drilled them out and used 4-40 screws with star washers and nuts to replace the rivets. No more hum. The 77 tube being a detector and 1st audio tube makes it susceptible to hum. Plus the audio runs full tilt to the 42 as there is no audio volume control.
Tony
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
