Threads: 113
City: The Villages
Hi Guys,
I have an interesting problem that is driving me crazy. On this AM/FM radio I have replaced all caps, tested the resistors, tested the tubes and replaced 2. I aligned it, both AM and FM with a VTVM and everything checked ok. The problem is that AM works great, but FM will not pick up any stations. Only dead air anywhere on the dial. Is there anything that anyone can think of? Any help will be appreciated.
http://www.nostalgiaair.org/Resources/572/M0025572.htm
https://www.radiomuseum.org/r/zenith_h7 ... h02z2.html
Eric
The Villages, FL
Threads: 268
So I'm a little lost. If you did the alignment for the FM section was it working then??
Threads: 113
City: The Villages
Hi Terry,
That's what is driving me crazy. The alignment went just the way it was supposed to, but just dead air.
Eric
The Villages, FL
Threads: 268
So you can pickup the FM signal from the generator @ 98mc?
(This post was last modified: 11-26-2018, 08:33 PM by Radioroslyn.)
Threads: 30
City: Wellborn Florida
The selector switch on those sets can be a pain. Try giving it a good cleaning.
Threads: 113
City: The Villages
I checked it again. @ 98 it comes through all over the dial. Does that tell you anything?
Eric
The Villages, FL
Threads: 113
City: The Villages
I cleaned the switch very thoroughly. No change. Thanks.
Eric
The Villages, FL
Threads: 113
City: The Villages
Happy new year everyone. Sorry it took a while to get back to you, but after reading, searching the internet and pulling my hair out, I found the problem. It was a bad cap on the FM osc. coil. I replaced it with a cap from a junk chassis and all is fine.
Thanks to everyone who had some input.
Eric
The Villages, FL
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
