2nd af trans
Hi, I'm looking for a 2nd AF trans for a Philco 87, #25 on the rider schematics. Checking it I got a double whammy, primary open and one secondary to the 45 tube open. If anybody has one to buy or knows what other radio I can scavenge from. Please let me know Thanks, Richard
Try looking thru the transformer listings on PlayThings of Past website:
http://www.oldradioparts.com
Gary has lots of parts - many Philco nos.
AES has replacement interstage transformers, even a coil to put on the old iron. https://secure.tubesandmore.com/new/scri...INTERSTAGE
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
There are currently 10506 online users. [Complete List]
» 2 Member(s) | 10504 Guest(s)
