RE-Cone Your Old Speaker for About $1
https://www.russoldradios.com/blog
great tutorial, thanks Russ!
Nice write-up!
With no other options, I did something similar for my 16X's speaker, it works well, and sounds great.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2132 online users. [Complete List]
» 1 Member(s) | 2131 Guest(s)
