Threads: 5
City: Cedar Rapids Iowa
Thanks Russ! Just so others can see the comment without needing to go to the page here it is:
"Tried to fix a broken wafer years ago...the super glue traveled down several wafers...everything got frozen...it became a parts set!"
I'm not sure how this could happen unless you were really careless with the super glue. This wafer is separated from the others by over an inch and a half. Of course, you'd have to make sure you kept it away from any of the contacts. Am I missing something?
Rich
Threads: 112
City: Medford OR (OR what?)
no. You are probably right. Be careful and aware that super glue might take a while to set.
Threads: 5
I think I've found a solution to the broken wafer on the function switch:
I designed and printed a reinforcement piece on my 3d printer. I plan to apply a small amount of epoxy to the inside surfaces of the 'legs' of the piece and slide it onto the wafer. I still want to come up with a way to apply a little side to side pressure to close the crack while the epoxy sets up.
Rich
Threads: 5
Hey Bill - I don't know why I didn't think of this before, but Michael LaRose did a 14 part series on his YouTube channel (ThatTubeSound) covering his restoration of a 47-1230. Check it out: https://www.youtube.com/watch?v=5vcvh0f4...OyzNZvIj9A
Rich
Threads: 46
City: Gap Mills Wv 24941
i am recalling something,,,
i got help determining my audio output transformer was bad and replaced it.
i still had no sound,,, granted this is well into the resto where i was expecting sound.
i think over at my loctal socket we finally found i had a carbon trace. I only found this by taking readings on each and every pin and paying particular attention to some of those lower voltages and the polarity of the readings showing up as neg & pos voltages.
once we found the carbon trace,,, i ordered some loctal's but headed back out to remove the socket,,, it was out in like 10 minutes.
i continued to dissect the socket cause i wanted to see for myself this mysterious carbon trace everyone was making a big deal about
sure enough the electrons had dug a ditch from a particular pin on through the phenol wafer over to another pin or chassis.
i knew i could attempt a fix so i sanded waffer down on 1000 grit then 2000 grit sand paper till the ditch was gone then put it back together.
in about an hour i had the old socket back in and got sound.
what i did is not recommended and unorthodox but doing so i knew would help me progress to having sound instead of waiting on the mail. I was looking to see if this provided the answer to no sound and it did.
Threads: 4
City: washington nj
Yes Rich, thank you, I've seen it many times. Bill
Threads: 5
I set the chassis for my 47-1230 aside for awhile while I do some more research to see if I can figure out why the FM doesn't work. So I decided to clean and lubricate the phonograph. All of the grease had dried and hardened so it was necessary to completely remove everything for cleaning. That in itself was difficult...the cam gear and the separator post in particular were extremely difficult to remove. Just a note to others that might be considering doing this but are afraid to do it because it looks complex...it really isn't difficult at all. It's just a bunch of levers and springs. Take your time...take lots of pictures...and keep everything organized. That being said, I don't know how difficult it will be to make sure everything is adjusted correctly, but it doesn't look too tough.
Here are before and after shots. The 'before' picture really doesn't show how grungy it was.
Now for my question. I don't see a way to lubricate the shaft for the pinion gear without taking the gear off. It's held in place on the shaft with a pin. How difficult is it to tap the pin out, remove the gear, lubricate the shaft, replace the gear, and tap the pin back in?
Rich
Threads: 3
City: Davis
State, Province, Country: CA
I've been getting ready to do this myself, and this series of videos (which I'm sure you've seen) really came in handy.
https://www.youtube.com/watch?v=xbC78xI_...9A&index=3
That top gear might be plastic, and I would be very reluctant to mess with that. You might just try to wick in some oil instead, and call it a day there. Pressed in pieces are not very forgiving.
Threads: 5
Thanks Mutantmoose! Yes, I've followed Michael for a long time and watched that series when he posted it, and have reviewed it recently. He does some great work! But I didn't see anywhere in his series where he lubricated either the metal pinion gear (or the cam gear for that matter) or the shaft it's attached to. The plastic gear on top is connected to the same shaft and I have no intention of trying to take it off. But if the metal gear was removed, the plastic gear would come out with the shaft. I'm wondering how hard it is to remove the pin that holds the metal pinion gear on.
Rich
Threads: 5
I get to answer my own question. The question was "how hard is it to remove the pin retaining the metal pinion gear"? The answer: NOT! I decided to give it a try so I got out a small punch and tapped on it a bit and was surprised that it moved. It took a good rap, but not excessively. Here it is with the pin part way out
And here is the plastic gear on the other end of the shaft
Now I have another question. Should I use oil on the shaft? Or should I use grease?
Rich
(This post was last modified: 12-21-2018, 05:10 PM by criageek.
Edit Reason: Add question
Threads: 2
City: Eugene, OR
I would just good a good oil like Zoom Spout but you could use a bit of something like phonolube if you have it.
Threads: 54
I would use grease on gears, but see if you can find the Philco service info on what to lube, and with what first.
Threads: 5
Thanks guys! I know to use grease on gears. I'm wondering what to use on the shaft that the metal pinion gear is attached to. I would post pictures of grease I'm using but my cable and internet have been down since Saturday night and won't be back until Wednesday afternoon...I'm at my Mom's place now (how is it that cable/internet is easily my most expensive utility, yet they are the worst at customer support??). I know I'm using 3-In-1 household oil, but don't remember the brand of grease. Wait...I bought it on Amazon...here it is:
https://www.amazon.com/Sta-Lube-SL3141-M...ube+SL3141
Rich
(This post was last modified: 12-24-2018, 01:07 PM by criageek.)
Threads: 24
City: Edmonton AB CA
Anywhere there is a shaft and bushing you should use an oil. In the old days a lite motor oil like 10W or 20W was recommended. The problem with those oils is after many years they get thick and gooey and don't lubricate any more. I have gone with a lite synthetic that is not ever supposed to get gooey but time will be the test of that claim.
Gregb
Threads: 5
I guess it's time for me to get back to trying to figure out why the FM doesn't work. I set it aside for a while and worked on the cabinet and the record changer.
I just ordered an idler and a needle for the record changer so once they get here I'll get them installed and go through the setup procedure for the phono and give it a test.
Once that's done all that remains is getting the FM to work. I subscribe to Jim Lindenas' YouTube channel ( https://www.youtube.com/channel/UCbi8mX2...YIxaIsl-lg) and have seen him use an SDR (software defined radio) many times to gather information and do troubleshooting. So I decided to order one...it looks like it should be here in a few days. Once I get it set up and tinker with it a bit my plan is to use it to see if I can find the FM local oscillator running and go from there. As a shot in the dark I may order new 7F8, 6AG5, and 7X7 tubes, as they all could have an effect on the FM. Back when I first started this project I did get all new tubes, so I'm skeptical about it being a tube problem.
Rich
Users browsing this thread: 78 Guest(s)
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
There are currently 4194 online users. [Complete List] » 2 Member(s) | 4192 Guest(s)
